Introdução
This guide shows how to replace an Ink Cartridge. This process requires no necessary tools or knowledge of the device.
O que você precisa
Open cover of the printer.
Open the cartridge cover by pressing down on the tab and lifting it up.
5 comentários
I cannot change the ink cartridges because when I press the Ink button they will not stop in a position where I can open the container. Nothing I've tried works -- can you help please? URGENT!!!
I actually found this quite easy because of your guide. There was no issue at all with replacing the ink cartridge in my printer and now I can print again! Is there anything else I need to worry about after I put the cartridge in? http://tonertown.com.au
Instruction intimates the ink carriage will be in position when parked. Not so…with it parked in the extreme right, you cannot get the ink cover open. jdw
