Ir para o conteúdo principal
Epson Stylus Photo 1400 Housing Replacement
O que você precisa
  1. Epson Stylus Photo 1400 Housing Replacement, Housing: passo 1, imagem 1 %32
    • Turn off the printer.
    • Disconnect all data connections coming into the printer such as USB, networkd cables, firewire, etc. as well as removing the power cord.
  2. Epson Stylus Photo 1400 Housing Replacement: passo 2, imagem 1 %32 Epson Stylus Photo 1400 Housing Replacement: passo 2, imagem 2 %32
    • Locate the IEEE cover in the back.
    • Gently slide the cover to the right to unlatch, then pull to remove it.
  3. Epson Stylus Photo 1400 Housing Replacement: passo 3, imagem 1 %32 Epson Stylus Photo 1400 Housing Replacement: passo 3, imagem 2 %32
    • Using a Phillips #2 screwdriver, remove the four 10 mm screws shown.
    • Remove the 6 mm screw that holds the rear housing in place.
  4. Epson Stylus Photo 1400 Housing Replacement: passo 4, imagem 1 %32 Epson Stylus Photo 1400 Housing Replacement: passo 4, imagem 2 %32
    • Remove the rear housing by pulling it backwards.
  5. Epson Stylus Photo 1400 Housing Replacement: passo 5, imagem 1 %32 Epson Stylus Photo 1400 Housing Replacement: passo 5, imagem 2 %32 Epson Stylus Photo 1400 Housing Replacement: passo 5, imagem 3 %32
    • Insert a plastic opening tool into the cutouts of the lower housing.
    • Release the two tabs of the side housing by lifting the tool in an upward motion.
    • Remove the side housing by pulling it outwards.
  6. Epson Stylus Photo 1400 Housing Replacement: passo 6, imagem 1 %32 Epson Stylus Photo 1400 Housing Replacement: passo 6, imagem 2 %32
    • Both side housings are attached by the same type of mechanism.
    • Using the same method, remove the other side housing.
  7. Epson Stylus Photo 1400 Housing Replacement: passo 7, imagem 1 %32 Epson Stylus Photo 1400 Housing Replacement: passo 7, imagem 2 %32 Epson Stylus Photo 1400 Housing Replacement: passo 7, imagem 3 %32
    • Lift the paper support.
    • Open the printer cover and front cover.
  8. Epson Stylus Photo 1400 Housing Replacement: passo 8, imagem 1 %32 Epson Stylus Photo 1400 Housing Replacement: passo 8, imagem 2 %32 Epson Stylus Photo 1400 Housing Replacement: passo 8, imagem 3 %32
    • Remove the four 10 mm Phillips #2 screws from the sides of the printer.
    • Remove the three 6 mm Phillips #2 screws.
  9. Epson Stylus Photo 1400 Housing Replacement: passo 9, imagem 1 %32 Epson Stylus Photo 1400 Housing Replacement: passo 9, imagem 2 %32
    • Detach the tabs from the pins on each side by pulling it outwards.
  10. Epson Stylus Photo 1400 Housing Replacement: passo 10, imagem 1 %32 Epson Stylus Photo 1400 Housing Replacement: passo 10, imagem 2 %32
    • Remove the two 10 mm Phillips #2 screws on the front of the printer.
  11. Epson Stylus Photo 1400 Housing Replacement: passo 11, imagem 1 %32 Epson Stylus Photo 1400 Housing Replacement: passo 11, imagem 2 %32 Epson Stylus Photo 1400 Housing Replacement: passo 11, imagem 3 %32
    • Disconnect the two cables on the side by carefully pulling it outwards.
    • You may need to gently rock the two cables up and down while pulling.
  12. Epson Stylus Photo 1400 Housing Replacement: passo 12, imagem 1 %32 Epson Stylus Photo 1400 Housing Replacement: passo 12, imagem 2 %32
    • Remove the upper housing by lifting it upwards.
    • It's easier to lift the housing by gripping it from the bottom.
Conclusão
10 outras pessoas executaram este guia.
Larry Huang
Membro desde: 10/12/11
1.004 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 17-11, Regan Fall 2011 Membro de Cal Poly, Team 17-11, Regan Fall 2011
CPSU-REGAN-F11S17G11
Membros da 4
Autoria de 12 guias
Um comentário
Thank you so much, Larry! I am repurposing my 1400 for sublimation printing and need to get the print head a little easier than standard methods! Much appreciated!
ryan Caputo - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 19
Duração total: 7,543
