Ir para o conteúdo principal
Epson Stylus NX305 Scanner Motor Replacement
O que você precisa
  1. Epson Stylus NX305 Scanner Motor Replacement, Scanner Motor: passo 1, imagem 1 %32
    • Make sure that the printer is not plugged in before working on it.
    • Orient the printer so that the back of it is facing you.
  2. Epson Stylus NX305 Scanner Motor Replacement: passo 2, imagem 1 %32
    • Locate the 3mm Phillips #0 screw that is on the right-hand side of the printer.
    • Using a Phillips head screwdriver, remove the screw.
  3. Epson Stylus NX305 Scanner Motor Replacement: passo 3, imagem 1 %32 Epson Stylus NX305 Scanner Motor Replacement: passo 3, imagem 2 %32
    • Open up the lid of the printer.
    • With the printer facing away from you, lift up on the right hand side of the lid of the printer and slide it to the left to remove it.
    • Be careful not to remove the white ribbon and wires that are connected.
  4. Epson Stylus NX305 Scanner Motor Replacement: passo 4, imagem 1 %32
    • With the printer facing you, open the lid of the scanner to expose the 3mm Phillips #0 screw at the top left of the scanner.
  5. Epson Stylus NX305 Scanner Motor Replacement: passo 5, imagem 1 %32
    • Locate the six 3mm Phillips #2 screws under the lid of the printer and remove them.
  6. Epson Stylus NX305 Scanner Motor Replacement: passo 6, imagem 1 %32
    • Locate the three clips on the front side of the printer lid.
    • Use the plastic opening tool to release the clips and carefully pry open the lid.
  7. Epson Stylus NX305 Scanner Motor Replacement: passo 7, imagem 1 %32
    • Locate the belt that is attached to the scanner motor and remove it by carefully stretching off of the gear.
  8. Epson Stylus NX305 Scanner Motor Replacement: passo 8, imagem 1 %32
    • Remove the two 3mm Phillips #2 screws from the scanner motor assembly.
    • Carefully lift the scanner motor assembly out of the housing making sure not to damage the wiring.
  9. Epson Stylus NX305 Scanner Motor Replacement: passo 9, imagem 1 %32
    • Flip over the scanner motor assembly to expose the scanner motor.
    • Remove the two 3mm Phillips #2 screws from the assembly and remove the motor.
Conclusão
Jeffrey Barnett
Membro desde: 09/21/14
101 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 1-2, Donnelly Fall 2014 Membro de USF Tampa, Team 1-2, Donnelly Fall 2014
USFT-DONNELLY-F14S1G2
1 Membro
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 11
Duração total: 470
