Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Align your printer so that the front buttons face to the right.
Remove the 3mm Phillips #2 screw in the hole in the top left corner. This screw attaches the side panel to the printer.
Flip and remove the top of the printer up so that you can see the inside.
There is a white strip in the top right corner of the printer called the ribbon cable.
Align the printer so the front button panel faces to the right.
Remove the 3mm Phillips #2 screw on the side of the printer in the top left corner.
Take the right side of the bar of plastic that runs across the top of the inside of the printer and push it towards the left side of the printer.
Take the left side of the bar and push it to the left and then to the right.
Using your hands, detach the side panel from the printer.
You may need to use the plastic opening tools to pry apart the locking mechanisms.
Remove the two 3mm Phillips #2 screws attaching motherboard to the printer.
