Ir para o conteúdo principal
Epson Stylus NX230 Motherboard Replacement
O que você precisa
  1. Epson Stylus NX230 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32
    • Check to make sure the printer is unplugged to prevent electric shock.
  2. Epson Stylus NX230 Motherboard Replacement: passo 2, imagem 1 %32 Epson Stylus NX230 Motherboard Replacement: passo 2, imagem 2 %32
    • Align your printer so that the front buttons face to the right.
    • Remove the 3mm Phillips #2 screw in the hole in the top left corner. This screw attaches the side panel to the printer.
    • Store the screws in a safe place so you can access them later.
  3. Epson Stylus NX230 Motherboard Replacement: passo 3, imagem 1 %32
    • Flip and remove the top of the printer up so that you can see the inside.
    • There is a white strip in the top right corner of the printer called the ribbon cable.
    • Make sure that the ribbon cable does not detach from the printer to prevent damaging the connection.
  4. Epson Stylus NX230 Motherboard Replacement: passo 4, imagem 1 %32 Epson Stylus NX230 Motherboard Replacement: passo 4, imagem 2 %32
    • Align the printer so the front button panel faces to the right.
    • Remove the 3mm Phillips #2 screw on the side of the printer in the top left corner.
    • Store the screw in a safe place so you can access it later.
  5. Epson Stylus NX230 Motherboard Replacement: passo 5, imagem 1 %32 Epson Stylus NX230 Motherboard Replacement: passo 5, imagem 2 %32
    • Take the right side of the bar of plastic that runs across the top of the inside of the printer and push it towards the left side of the printer.
    • Take the left side of the bar and push it to the left and then to the right.
  6. Epson Stylus NX230 Motherboard Replacement: passo 6, imagem 1 %32 Epson Stylus NX230 Motherboard Replacement: passo 6, imagem 2 %32 Epson Stylus NX230 Motherboard Replacement: passo 6, imagem 3 %32
    • Using your hands, detach the side panel from the printer.
    • Take extra care with the locking mechanisms, which help keep the side panel on the printer.
    • You may need to use the plastic opening tools to pry apart the locking mechanisms.
  7. Epson Stylus NX230 Motherboard Replacement: passo 7, imagem 1 %32
    • Remove the two 3mm Phillips #2 screws attaching motherboard to the printer.
    • The motherboard can now be removed from the printer.
Conclusão
Kimberly Pugel
Membro desde: 04/07/14
404 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 6-1, Forte Spring 2014 Membro de Cal Poly, Team 6-1, Forte Spring 2014
CPSU-FORTE-S14S6G1
Membros da 4
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 9
Duração total: 1,174
