Ir para o conteúdo principal
Epson PowerLite Home Cinema 1040 Air Filter Replacement
  1. Epson PowerLite Home Cinema 1040 Air Filter Replacement, Air Filter: passo 1, imagem 1 %32
    • Turn off the projector and unplug the power cord.
  2. Epson PowerLite Home Cinema 1040 Air Filter Replacement: passo 2, imagem 1 %32
    • Locate the air filter cover located on the top of the projector on the nearest side adjacent to the lens
    • Remove the air filter cover by gripping the ridge underneath it and pulling upwards
  3. Epson PowerLite Home Cinema 1040 Air Filter Replacement: passo 3, imagem 1 %32
    • Pull the air filter out of the projector by gripping the black tab on the top of the air filter
    • The air filter contains ABS resin and polyurethane foam; dispose according to local regulations
  4. Epson PowerLite Home Cinema 1040 Air Filter Replacement: passo 4, imagem 1 %32
    • Push the new air filter gently into place until there is a click
Conclusão
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 19
Duração total: 102
