Ir para o conteúdo principal
Epson PowerLite 77c Button Panel Replacement
O que você precisa
  1. Epson PowerLite 77c Button Panel Replacement, Top Panel: passo 1, imagem 1 %32
    • Use a Phillips #0 screwdriver to remove the seven 5.0 mm screws on the base panel.
    • Pick up the projector with both hands, sandwiching the top and bottom of the projector together, and place it right-side-up, with the ports facing you.
    • Lift the top panel up.
    • Two connectors are holding the top panel to the motherboard; be careful not to damage them as you lift the top panel.
  2. Epson PowerLite 77c Button Panel Replacement: passo 2, imagem 1 %32 Epson PowerLite 77c Button Panel Replacement: passo 2, imagem 2 %32
    • Flip the locking bar of the ZIF connector vertically, then delicately remove the ribbon cable.
    • Grip the cable connector as close as possible to the plug, then pull it straight up until it releases from the motherboard.
    • Remove the top panel.
  3. Epson PowerLite 77c Button Panel Replacement, Button Panel: passo 3, imagem 1 %32
    • On the underside of the top panel, use a Phillips #0 to remove the four screws securing the button panel.
  4. Epson PowerLite 77c Button Panel Replacement: passo 4, imagem 1 %32
    • Remove the button panel.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 12
Duração total: 76
