Ir para o conteúdo principal
Epson PowerLite 822 Plus Exhaust Fan Replacement
O que você precisa
  1. Epson PowerLite  822 Plus Exhaust Fan Replacement, Motherboard: passo 1, imagem 1 %32
    • Flip the projector over.
    • Remove all 8 screws on the bottom of the projector.
  2. Epson PowerLite  822 Plus Exhaust Fan Replacement: passo 2, imagem 1 %32 Epson PowerLite  822 Plus Exhaust Fan Replacement: passo 2, imagem 2 %32
    • Now, flip the projector back over and pry the top of it open revealing the inside of the projector.
  3. Epson PowerLite  822 Plus Exhaust Fan Replacement: passo 3, imagem 1 %32 Epson PowerLite  822 Plus Exhaust Fan Replacement: passo 3, imagem 2 %32
    • Use the spudger to disconnect it from the motherboard.
  4. Epson PowerLite  822 Plus Exhaust Fan Replacement: passo 4, imagem 1 %32 Epson PowerLite  822 Plus Exhaust Fan Replacement: passo 4, imagem 2 %32
    • Using your finger gently move back and forth the JST cable that connects the top to the motherboard.
    • Now completely take off the top of the projector.
  5. Epson PowerLite  822 Plus Exhaust Fan Replacement: passo 5, imagem 1 %32 Epson PowerLite  822 Plus Exhaust Fan Replacement: passo 5, imagem 2 %32
    • Remove the 3 screws that secure the motherboard in place.
  6. Epson PowerLite  822 Plus Exhaust Fan Replacement: passo 6, imagem 1 %32 Epson PowerLite  822 Plus Exhaust Fan Replacement: passo 6, imagem 2 %32 Epson PowerLite  822 Plus Exhaust Fan Replacement: passo 6, imagem 3 %32
    • Gently move back and forth the 11 JST connectors until they come out.
  7. Epson PowerLite  822 Plus Exhaust Fan Replacement: passo 7, imagem 1 %32 Epson PowerLite  822 Plus Exhaust Fan Replacement: passo 7, imagem 2 %32
    • With the spudger lift the red plastic tabs from their connectors.
  8. Epson PowerLite  822 Plus Exhaust Fan Replacement: passo 8, imagem 1 %32 Epson PowerLite  822 Plus Exhaust Fan Replacement: passo 8, imagem 2 %32 Epson PowerLite  822 Plus Exhaust Fan Replacement: passo 8, imagem 3 %32
    • Lift the motherboard and disconnect the JST connector underneath.
  9. Epson PowerLite  822 Plus Exhaust Fan Replacement: passo 9, imagem 1 %32
    • Now, the motherboard is completely removed from the projector and you are ready to replace it.
  10. Epson PowerLite  822 Plus Exhaust Fan Replacement, Projector Lens: passo 10, imagem 1 %32 Epson PowerLite  822 Plus Exhaust Fan Replacement, Projector Lens: passo 10, imagem 2 %32 Epson PowerLite  822 Plus Exhaust Fan Replacement, Projector Lens: passo 10, imagem 3 %32
    • Unscrew the four 6mm screws that hold together the fan bracket.
  11. Epson PowerLite  822 Plus Exhaust Fan Replacement: passo 11, imagem 1 %32 Epson PowerLite  822 Plus Exhaust Fan Replacement: passo 11, imagem 2 %32
    • Unscrew the four 6mm screws that secure the projector.
  12. Epson PowerLite  822 Plus Exhaust Fan Replacement: passo 12, imagem 1 %32 Epson PowerLite  822 Plus Exhaust Fan Replacement: passo 12, imagem 2 %32
    • Pull out the loose projector.
  13. Epson PowerLite  822 Plus Exhaust Fan Replacement, Exhaust Fan: passo 13, imagem 1 %32 Epson PowerLite  822 Plus Exhaust Fan Replacement, Exhaust Fan: passo 13, imagem 2 %32
    • Gently lift the fan bracket up and remove it and it is ready to be replaced.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 11
Ao todo: 174
