Ir para o conteúdo principal
Epson Perfection V33 Main Housing Removal
O que você precisa
    • Open up the lid to the flatbed scanner.
    • It can help with the next step if you lift it so it bends out flat to the other side.
    Pergunte ao FixBot
    Comentar
  1. Ferramenta utilizada neste passo:
    • On each side of the open hinge there are two large Phillips screws on either side.
    • Use a Phillips screwdriver to unscrew them and lift them out with tweezers.
    • Be careful and avoid dropping the screws on the scanning glass so you don't scratch it.
    Pergunte ao FixBot
    Comentar
    • Gently lift the top casing of the scanner up from the side where you unscrewed the area around the lid hinge, at the corner opposite to where the buttons are located.
    • While holding it up at an angle like that, slide the casing towards the opposite side of the hinge.
    • The top casing can now be gently lifted off.
    Pergunte ao FixBot
    Comentar
Conclusão
Caius Nocturne
Membro desde: 07/12/21
2.106 Reputação
Autoria de 13 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 26
Ao todo: 455
