Ir para o conteúdo principal
Epson PPC650 Camera Case Replacement
O que você precisa
  1. Epson PPC650 Camera Case Replacement, Case: passo 1, imagem 1 %32 Epson PPC650 Camera Case Replacement, Case: passo 1, imagem 2 %32 Epson PPC650 Camera Case Replacement, Case: passo 1, imagem 3 %32
    • Make sure the camera is turned off here.
    • Remove batteries from the battery compartment located on the bottom of the camera
    • Remove SD card for the card reader compartment located on the flat side (left side) of the camera
  2. Epson PPC650 Camera Case Replacement: passo 2, imagem 1 %32
    • Remove 2 screws on the rounded side of the camera wisdom here.
  3. Epson PPC650 Camera Case Replacement: passo 3, imagem 1 %32 Epson PPC650 Camera Case Replacement: passo 3, imagem 2 %32
    • Remove 3 screws on the flat side of the camera
    • All silver screws go into the side of the camera that is silver
    • All black screws go into the side of the camera that is black
  4. Epson PPC650 Camera Case Replacement: passo 4, imagem 1 %32
    • Remove 4 screws from the bottom of the camera
  5. Epson PPC650 Camera Case Replacement: passo 5, imagem 1 %32 Epson PPC650 Camera Case Replacement: passo 5, imagem 2 %32 Epson PPC650 Camera Case Replacement: passo 5, imagem 3 %32
    • Separate the front and back pieces of the cameras plastic casing using a spudgerm here.
    • WARNING: When pulling the front plastic casing, be careful of the wire that are connected to the aperture control
    • Use minimal force so that the plastic casing does not break
    • When separating the small silver sliding indicator for view/off/playback may fall out
    • The plastic viewing window located on the top of the camera may also become lose and fall out
Conclusão
Brittany
Membro desde: 02/12/13
101 Reputação
Autoria de 1 guia
Equipe
Ohio State, Team 1-5, Buehl Spring 2013 Membro de Ohio State, Team 1-5, Buehl Spring 2013
OSU-BUEHL-S13S1G5
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 6
Duração total: 148
