Ir para o conteúdo principal
Epson Home Cinema 2150 Speaker Replacement
O que você precisa
  1. Epson Home Cinema 2150 Speaker Replacement, Projector Lamp: passo 1, imagem 1 %32 Epson Home Cinema 2150 Speaker Replacement, Projector Lamp: passo 1, imagem 2 %32 Epson Home Cinema 2150 Speaker Replacement, Projector Lamp: passo 1, imagem 3 %32
    • Disconnect and cool the device to room temperature. Failure to do so may result in electric shock or minor burns.
    • Orient the Epson Home Cinema 2150 so that the large indented panel faces your direction.
    • Unscrew the single 6mm Phillips#2 holding screw from the access panel.
    • Slide the panel horizontally, then lift up to remove the access panel.
  2. Epson Home Cinema 2150 Speaker Replacement: passo 2, imagem 1 %32 Epson Home Cinema 2150 Speaker Replacement: passo 2, imagem 2 %32 Epson Home Cinema 2150 Speaker Replacement: passo 2, imagem 3 %32
    • Loosen and remove the two screws holding the lamp.
    • Remove two 9 mm Phillips #2 screws.
  3. Epson Home Cinema 2150 Speaker Replacement: passo 3, imagem 1 %32 Epson Home Cinema 2150 Speaker Replacement: passo 3, imagem 2 %32 Epson Home Cinema 2150 Speaker Replacement: passo 3, imagem 3 %32
    • Using four fingers, pull upwards on the lamp's plastic casing.
    • You may feel some resistance when pulling the lamp.
  4. Epson Home Cinema 2150 Speaker Replacement, Wireless connection board: passo 4, imagem 1 %32 Epson Home Cinema 2150 Speaker Replacement, Wireless connection board: passo 4, imagem 2 %32 Epson Home Cinema 2150 Speaker Replacement, Wireless connection board: passo 4, imagem 3 %32
    • Remove the air filter cover. Grip the piece with two fingers above and below at the center.
    • Grab the air filter from the protruding tab and pull the filter out.
  5. Epson Home Cinema 2150 Speaker Replacement: passo 5, imagem 1 %32 Epson Home Cinema 2150 Speaker Replacement: passo 5, imagem 2 %32
    • From the back of the projector remove three 6 mm Phillips #1 screws.
  6. Epson Home Cinema 2150 Speaker Replacement: passo 6, imagem 1 %32 Epson Home Cinema 2150 Speaker Replacement: passo 6, imagem 2 %32 Epson Home Cinema 2150 Speaker Replacement: passo 6, imagem 3 %32
    • From the device's underside, remove eleven 9.5 mm Phillips #1 screws.
    • Remove two 6 mm Phillips #1 screws.
    • Pull off remaining plastic molding.
  7. Epson Home Cinema 2150 Speaker Replacement: passo 7, imagem 1 %32 Epson Home Cinema 2150 Speaker Replacement: passo 7, imagem 2 %32
    • From the lamp access slot, remove four 9.5 mm Philips #1 screws
  8. Epson Home Cinema 2150 Speaker Replacement: passo 8, imagem 1 %32 Epson Home Cinema 2150 Speaker Replacement: passo 8, imagem 2 %32 Epson Home Cinema 2150 Speaker Replacement: passo 8, imagem 3 %32
    • From the filter slot, unscrew two 9.5 mm #1 screws.
  9. Epson Home Cinema 2150 Speaker Replacement: passo 9, imagem 1 %32 Epson Home Cinema 2150 Speaker Replacement: passo 9, imagem 2 %32 Epson Home Cinema 2150 Speaker Replacement: passo 9, imagem 3 %32
    • Partially lift the top portion of the device housing.
    • Lifting too far or too hard may damage any cables between the housing and the motherboard.
  10. Epson Home Cinema 2150 Speaker Replacement: passo 10, imagem 1 %32 Epson Home Cinema 2150 Speaker Replacement: passo 10, imagem 2 %32 Epson Home Cinema 2150 Speaker Replacement: passo 10, imagem 3 %32
    • Disconnect the ribbon cable from the motherboard.
    • Ribbon cables are delicate. To avoid unnecessary stress to the cable, pull on the cable with the flat surface of two fingers.
  11. Epson Home Cinema 2150 Speaker Replacement: passo 11, imagem 1 %32 Epson Home Cinema 2150 Speaker Replacement: passo 11, imagem 2 %32 Epson Home Cinema 2150 Speaker Replacement: passo 11, imagem 3 %32
    • Remove three 5 mm Phillips #1 screws.
  12. Epson Home Cinema 2150 Speaker Replacement: passo 12, imagem 1 %32 Epson Home Cinema 2150 Speaker Replacement: passo 12, imagem 2 %32
    • Press on the metal connector and firmly pull on the remaining ribbon cable.
  13. Epson Home Cinema 2150 Speaker Replacement: passo 13, imagem 1 %32 Epson Home Cinema 2150 Speaker Replacement: passo 13, imagem 2 %32 Epson Home Cinema 2150 Speaker Replacement: passo 13, imagem 3 %32
    • Pull the clips on the case with two fingers on opposite ends and remove the case.
  14. Epson Home Cinema 2150 Speaker Replacement, Speaker: passo 14, imagem 1 %32 Epson Home Cinema 2150 Speaker Replacement, Speaker: passo 14, imagem 2 %32 Epson Home Cinema 2150 Speaker Replacement, Speaker: passo 14, imagem 3 %32
    • Pull up on the rear panel retaining clip.
    • Pull the rear panel away from the device to remove.
  15. Epson Home Cinema 2150 Speaker Replacement: passo 15, imagem 1 %32 Epson Home Cinema 2150 Speaker Replacement: passo 15, imagem 2 %32
    • Disconnect the speaker wire from the motherboard.
    • Pull up at the end of the wire when removing the connector.
  16. Epson Home Cinema 2150 Speaker Replacement: passo 16, imagem 1 %32 Epson Home Cinema 2150 Speaker Replacement: passo 16, imagem 2 %32 Epson Home Cinema 2150 Speaker Replacement: passo 16, imagem 3 %32
    • Unwind the speaker wire through the metal chassis.
  17. Epson Home Cinema 2150 Speaker Replacement: passo 17, imagem 1 %32 Epson Home Cinema 2150 Speaker Replacement: passo 17, imagem 2 %32 Epson Home Cinema 2150 Speaker Replacement: passo 17, imagem 3 %32
    • Remove two 6mm Phillips #1 screws.
    • The speaker will fall out once screws are removed.
Conclusão
Luis Garcia
Membro desde: 09/26/22
577 Reputação
Autoria de 4 guias
Equipe
CSU Los Angeles, Team 6-2, Adachi Fall 2022 Membro de CSU Los Angeles, Team 6-2, Adachi Fall 2022
CSULA-ADACHI-F22S6G2
Membros da 4
Autoria de 5 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 108
