Ir para o conteúdo principal
Epiphone Les Paul Special Input Jack Replacement
O que você precisa
  1. Epiphone Les Paul Special Input Jack Replacement, Input Jack: passo 1, imagem 1 %32
    • Using a Phillips #1 screwdriver, remove the four 7 mm screws holding the input jack cover.
  2. Epiphone Les Paul Special Input Jack Replacement: passo 2, imagem 1 %32
    • With a 12 mm wrench, remove the nut holding the input jack in place.
  3. Epiphone Les Paul Special Input Jack Replacement: passo 3, imagem 1 %32 Epiphone Les Paul Special Input Jack Replacement: passo 3, imagem 2 %32
    • Lift off the tone control knob.
  4. Epiphone Les Paul Special Input Jack Replacement: passo 4, imagem 1 %32
    • Using an 11 mm wrench, remove the nut of the tone control.
  5. Epiphone Les Paul Special Input Jack Replacement: passo 5, imagem 1 %32
    • With a Phillips #1 screwdriver, remove the three 7 mm screws holding on the back plate.
  6. Epiphone Les Paul Special Input Jack Replacement: passo 6, imagem 1 %32 Epiphone Les Paul Special Input Jack Replacement: passo 6, imagem 2 %32
    • Pull out the tone control.
  7. Epiphone Les Paul Special Input Jack Replacement: passo 7, imagem 1 %32 Epiphone Les Paul Special Input Jack Replacement: passo 7, imagem 2 %32
    • Push the input jack through the body and pull it out.
  8. Epiphone Les Paul Special Input Jack Replacement: passo 8, imagem 1 %32
    • The soldering iron is very hot. Avoid contact with skin, as well as the body of the instrument. When not in use, place it on a soldering iron stand.
    • Desolder the wires from the input jack.
  9. Epiphone Les Paul Special Input Jack Replacement: passo 9, imagem 1 %32
    • Solder the wires to the input jack.
    • Repeat steps 7-1 in reverse order to put it all back together.
Conclusão
To get everything back into its original place, follow steps 1-7 in reverse order.
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 5
Últimos 7 dias: 35
Últimos 30 dias: 164
Duração total: 2,513
