Ir para o conteúdo principal
Epiphone ES-335 PRO Tuner Replacement
O que você precisa
  1. Epiphone ES-335 PRO Tuner Replacement, Strings: passo 1, imagem 1 %32 Epiphone ES-335 PRO Tuner Replacement, Strings: passo 1, imagem 2 %32
    • Using the tuner, loosen the string by turning the tuner.
    • Continue to loosen the string until it is easily unwrapped and pulled out of the tuner.
  2. Epiphone ES-335 PRO Tuner Replacement: passo 2, imagem 1 %32
    • On the bridge of the guitar, push the string through the back until the other end is visible. Then grasp and pull the string all the way out.
  3. Epiphone ES-335 PRO Tuner Replacement, Tuner: passo 3, imagem 1 %32
    • Using a phillips head #2 screwdriver, unscrew the two 1.0 mm length screws on the sides of the tuner.
    • Be sure to keep track of the screws if you are using them for the new tuner, unless the new tuner has screws of its own.
  4. Epiphone ES-335 PRO Tuner Replacement: passo 4, imagem 1 %32
    • The tuner should come right out of the back of the head of the guitar.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 12
Duração total: 1,440
