Ir para o conteúdo principal
Epiphone ES-335 PRO Pickguard Replacement
O que você precisa
  1. Epiphone ES-335 PRO Pickguard Replacement, Pickguard: passo 1, imagem 1 %32
    • Locate the screw closest to the neck of the guitar.
    • Use a phillips head #2 screwdriver to completely unscrew the 1.0 mm length screw.
    • Be sure to keep any screws together as you will use them again, unless the replacement pickguard has its own screws.
  2. Epiphone ES-335 PRO Pickguard Replacement: passo 2, imagem 1 %32 Epiphone ES-335 PRO Pickguard Replacement: passo 2, imagem 2 %32
    • Using a phillips head #2 screwdriver, completely unscrew the 1.0 mm length screw.
    • Gently lift the pickguard off the body of the guitar.
Conclusão
Um comentário
very nice and simple demo, but where would you get a new pickguard, as Epiphone will not
supply them and other aftermarket guards will not fit.
peterattard1 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 18
Últimos 30 dias: 75
Duração total: 5,277
