Ir para o conteúdo principal
Entry Door Weatherstripping Replacement
O que você precisa
  1. Entry Door Weatherstripping Replacement, Weatherstripping: passo 1, imagem 1 %32 Entry Door Weatherstripping Replacement, Weatherstripping: passo 1, imagem 2 %32
    • Use the putty knife to loosen the weatherstripping from the groove.
    • Push outwards from the groove using the putty knife, so the groove doesn't get damaged.
    • The groove is located behind the exterior of the door frame
  2. Entry Door Weatherstripping Replacement: passo 2, imagem 1 %32 Entry Door Weatherstripping Replacement: passo 2, imagem 2 %32 Entry Door Weatherstripping Replacement: passo 2, imagem 3 %32
    • Pull out the Weatherstripping from the groove
    • Use the putty knife if assistance is needed by pushing the weatherstripping outward from the groove
  3. Entry Door Weatherstripping Replacement: passo 3, imagem 1 %32
    • After removing the weatherstripping, measure the door frame using the measuring tape.
  4. Entry Door Weatherstripping Replacement: passo 4, imagem 1 %32 Entry Door Weatherstripping Replacement: passo 4, imagem 2 %32
    • After measuring the door use a pen to mark the new weatherstrip and cut it with the scissors.
    • Be careful when handling scissors.
  5. Entry Door Weatherstripping Replacement: passo 5, imagem 1 %32 Entry Door Weatherstripping Replacement: passo 5, imagem 2 %32
    • Using the putty knife, push the new weatherstripping into the door groove.
  6. Entry Door Weatherstripping Replacement: passo 6, imagem 1 %32 Entry Door Weatherstripping Replacement: passo 6, imagem 2 %32 Entry Door Weatherstripping Replacement: passo 6, imagem 3 %32
    • Repeat the process from steps 1-5 for the weatherstrip for the top and left of the doorframe.
  7. Entry Door Weatherstripping Replacement: passo 7, imagem 1 %32
    • Now measure the door’s width using the measuring tape.
  8. Entry Door Weatherstripping Replacement: passo 8, imagem 1 %32 Entry Door Weatherstripping Replacement: passo 8, imagem 2 %32
    • Install the Door Sweep by drilling it in using a cordless drill.
    • Drill can be hazardous if not handled with care
Conclusão
Agilakumaran Shanmugalingam
Membro desde: 05/10/21
157 Reputação
Autoria de 1 guia
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 19
Últimos 30 dias: 105
Duração total: 6,728
