Ir para o conteúdo principal
Engine Brake Disassembly
O que você precisa
  1. Engine Brake Disassembly, Remove spring and brackets: passo 1, imagem 1 %32
    • Remove the return spring by using needle nose pliers, a screwdriver, or other device. I removed the spring by the end of the front bracket (away from the mower handle). Lift up and away from the bracket, and the spring should come out.
    • Beware! The spring is very strong and injury could result if proper care is not exercised.
    • Remove the two bolts using a 7/16 socket.
  2. Engine Brake Disassembly, Remove alternator wire: passo 2, imagem 1 %32
    • Push the metal tab closest to the black wire down
    • While pushing the tab down, pull the black wire out of the clip.
    • Disassembly is complete!
Conclusão
Jacob Micallef
Membro desde: 03/06/17
993 Reputação
Autoria de 7 guias
0 comentários
Comentar
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Ao todo: 291
