Ir para o conteúdo principal
Engage Wired Optical Mouse Top and Outer Shell Removal
O que você precisa
  1. Engage Wired Optical Mouse Top and Outer Shell Removal, Engage Wired Optical Mouse Top and Outer Shell Removal: passo 1, imagem 1 %32
    • Flip the mouse over and peel off the stickers on the perimeter of the bottom of the mouse.
  2. Engage Wired Optical Mouse Top and Outer Shell Removal: passo 2, imagem 1 %32
    • Use the Phillips #1 screwdriver to remove four 5 mm screws from the bottom of the mouse.
    • Use the Phillips #1 screwdriver to remove the two 9 mm screws from the bottom of the mouse.
  3. Engage Wired Optical Mouse Top and Outer Shell Removal: passo 3, imagem 1 %32 Engage Wired Optical Mouse Top and Outer Shell Removal: passo 3, imagem 2 %32 Engage Wired Optical Mouse Top and Outer Shell Removal: passo 3, imagem 3 %32
    • Grab the top shell of the mouse and lift up to remove.
  4. Engage Wired Optical Mouse Top and Outer Shell Removal: passo 4, imagem 1 %32
    • The capacitors on this board can release stored electrical energy if touched.
    • Touch your capacitor discharge tool to the capacitor leads on the board to release the stored energy. If leads are inaccessible, wait until you've removed the board from the mouse body.
  5. Engage Wired Optical Mouse Top and Outer Shell Removal: passo 5, imagem 1 %32 Engage Wired Optical Mouse Top and Outer Shell Removal: passo 5, imagem 2 %32
    • Use a spudger to pry underneath the white plug and pop it out to disconnect the upper board from the lower board.
Conclusão
royceeklund
Membro desde: 01/18/13
79 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 18-36, Regan Winter 2013 Membro de Cal Poly, Team 18-36, Regan Winter 2013
CPSU-REGAN-W13S18G36
Membros da 3
Autoria de 30 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 26
Duração total: 3,491
