Ir para o conteúdo principal
Enagic Water Filter SD501 Platinum Filter Replacement
O que você precisa
  1. Enagic Water Filter SD501 Platinum Filter Replacement, Filter: passo 1, imagem 1 %32
    • Turn off and unplug the machine before cleaning it.
    • Clean the machine with a damp cloth or paper towel.
    • Make sure nothing dirty will get in the machine during the process.
  2. Enagic Water Filter SD501 Platinum Filter Replacement: passo 2, imagem 1 %32 Enagic Water Filter SD501 Platinum Filter Replacement: passo 2, imagem 2 %32 Enagic Water Filter SD501 Platinum Filter Replacement: passo 2, imagem 3 %32
    • Open the filter door by pushing the "Push" button.
  3. Enagic Water Filter SD501 Platinum Filter Replacement: passo 3, imagem 1 %32 Enagic Water Filter SD501 Platinum Filter Replacement: passo 3, imagem 2 %32 Enagic Water Filter SD501 Platinum Filter Replacement: passo 3, imagem 3 %32
    • Turn the ring at the bottom of the filter to the left until you hear a "click".
  4. Enagic Water Filter SD501 Platinum Filter Replacement: passo 4, imagem 1 %32 Enagic Water Filter SD501 Platinum Filter Replacement: passo 4, imagem 2 %32
    • Remove the ring for now.
  5. Enagic Water Filter SD501 Platinum Filter Replacement: passo 5, imagem 1 %32 Enagic Water Filter SD501 Platinum Filter Replacement: passo 5, imagem 2 %32
    • Lift up the old filter and discard or recycle appropriately.
    • Some water might be dripping out from the bottom of it. Have a towel ready to clean it up.
  6. Enagic Water Filter SD501 Platinum Filter Replacement: passo 6, imagem 1 %32 Enagic Water Filter SD501 Platinum Filter Replacement: passo 6, imagem 2 %32 Enagic Water Filter SD501 Platinum Filter Replacement: passo 6, imagem 3 %32
    • Remove the two black rubber rings.
    • They are NOT components of the machine. The new filter you have prepared should come with new ones.
  7. Enagic Water Filter SD501 Platinum Filter Replacement: passo 7, imagem 1 %32 Enagic Water Filter SD501 Platinum Filter Replacement: passo 7, imagem 2 %32 Enagic Water Filter SD501 Platinum Filter Replacement: passo 7, imagem 3 %32
    • Put your new filter in it.
    • Make sure that the two holes match the two popped-out parts from the filter.
    • The one that is bigger should be on the middle and the smaller one should be on the side.
    • This filter should be the new one that you have prepared and NOT the one that is removed from Step 5.
  8. Enagic Water Filter SD501 Platinum Filter Replacement: passo 8, imagem 1 %32 Enagic Water Filter SD501 Platinum Filter Replacement: passo 8, imagem 2 %32 Enagic Water Filter SD501 Platinum Filter Replacement: passo 8, imagem 3 %32
    • Put the ring component back in.
    • Turn it to your right until you hear a click.
    • Make sure it is successfully locked in.
  9. Enagic Water Filter SD501 Platinum Filter Replacement: passo 9, imagem 1 %32 Enagic Water Filter SD501 Platinum Filter Replacement: passo 9, imagem 2 %32 Enagic Water Filter SD501 Platinum Filter Replacement: passo 9, imagem 3 %32
    • Turn the filter back on.
    • Press the "Reset Switch"
    • "FILTER RESET" should be shown on the display.
  10. Enagic Water Filter SD501 Platinum Filter Replacement: passo 10, imagem 1 %32 Enagic Water Filter SD501 Platinum Filter Replacement: passo 10, imagem 2 %32 Enagic Water Filter SD501 Platinum Filter Replacement: passo 10, imagem 3 %32
    • Attach the filter door.
    • There are three holes to slide the door edge into.
    • And push the "push" button to close it.
Conclusão
To change another filter, simply just follow the instructions once more.
Edwin Ng
Membro desde: 09/12/21
181 Reputação
Autoria de 1 guia
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 8
Últimos 30 dias: 60
Duração total: 1,712
