Introdução
In order to open your device to gain access to the parts inside your device you will need to follow this steps closely . You will need certain tools such as a Phillips Head screwdriver, #00 3mm screws, spudger, plastic opening tool, as well as careful movements so you don't break any other components.
O que você precisa
Use a Phillips 00 bit to remove two 3mm screws from the bottom of the tablet.
Uma outra pessoa concluiu este guia.
