Ir para o conteúdo principal
Ematic Genesis 2 Screen Replacement
O que você precisa
  1. Ematic Genesis 2 Screen Replacement, Screen: passo 1, imagem 1 %32 Ematic Genesis 2 Screen Replacement, Screen: passo 1, imagem 2 %32
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
  2. Ematic Genesis 2 Screen Replacement: passo 2, imagem 1 %32 Ematic Genesis 2 Screen Replacement: passo 2, imagem 2 %32 Ematic Genesis 2 Screen Replacement: passo 2, imagem 3 %32
    • Remove all four screws surrounding the battery with a Phillips Head Screwdriver.
    • Carefully remove the battery from the device using the Metal Spudger tool to gently separate the battery by wedging it between the device and the battery.
  3. Ematic Genesis 2 Screen Replacement: passo 3, imagem 1 %32 Ematic Genesis 2 Screen Replacement: passo 3, imagem 2 %32
    • Remove the three screws surrounding the circuit board using the Phillips Head Screwdriver.
    • Remove the circuit board from the device by uncliping the copper flexible PCB ribbon cable from the circuit board.
  4. Ematic Genesis 2 Screen Replacement: passo 4, imagem 1 %32
    • Use the Small Pointed Metal Spudger to separate the LED screen from the front screen by gently wedging the spudger between the screen and the device.
  5. Ematic Genesis 2 Screen Replacement: passo 5, imagem 1 %32
    • Remove the glass from the front casing by using the metal spudger to break it free from the device. (It's held together by glue.)
    • Install the new screen.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 6
Duração total: 444
