Ir para o conteúdo principal
Ematic Genesis 2 Charging Port Replacement
O que você precisa
  1. Ematic Genesis 2 Charging Port Replacement, Charging Port: passo 1, imagem 1 %32 Ematic Genesis 2 Charging Port Replacement, Charging Port: passo 1, imagem 2 %32
    • With your fingers, carefully pry off the back plastic casing. Starting at the corners is usually the easiest.
  2. Ematic Genesis 2 Charging Port Replacement: passo 2, imagem 1 %32 Ematic Genesis 2 Charging Port Replacement: passo 2, imagem 2 %32 Ematic Genesis 2 Charging Port Replacement: passo 2, imagem 3 %32
    • Remove all four screws surrounding the battery with the Phillips head screwdriver.
    • Carefully remove the battery from the device using the Metal Spudger tool to gently separate the battery by wedging it between the device and the battery.
  3. Ematic Genesis 2 Charging Port Replacement: passo 3, imagem 1 %32 Ematic Genesis 2 Charging Port Replacement: passo 3, imagem 2 %32
    • Remove both screws on either side of the audio jack using the Philips head screwdriver.
    • Detach audio jack from device.
  4. Ematic Genesis 2 Charging Port Replacement: passo 4, imagem 1 %32 Ematic Genesis 2 Charging Port Replacement: passo 4, imagem 2 %32
    • Remove the 3 screws surrounding the circuit board using the Philips head screwdriver.
    • Carefully disconnect the circuit board from the device by detaching the copper flexible PCB ribbon cable.
  5. Ematic Genesis 2 Charging Port Replacement: passo 5, imagem 1 %32 Ematic Genesis 2 Charging Port Replacement: passo 5, imagem 2 %32
    Ferramenta utilizada neste passo:
    • Use a soldering iron to heat the solder holding the charging port to the circuit board.
    • Remove the charging port from board using tweezers.
  6. Ematic Genesis 2 Charging Port Replacement: passo 6, imagem 1 %32
    • Solder replacement port into place.
    • Make sure all connections match original.
Conclusão
Uma outra pessoa concluiu este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 624
