Ir para o conteúdo principal
Ematic Funtab FTABXXX Speaker Replacement
O que você precisa
  1. Ematic Funtab FTABXXX Speaker Replacement, Opening the Device: passo 1, imagem 1 %32 Ematic Funtab FTABXXX Speaker Replacement, Opening the Device: passo 1, imagem 2 %32
    • First, be sure to power off the device.
    • Carefully pry open the device. Note the plastic tabs in the image that hold the device together.
  2. Ematic Funtab FTABXXX Speaker Replacement, Locating the speaker: passo 2, imagem 1 %32
    • Locate the speaker in the bottom right hand side of the device. Note the red and black wires attaching the speaker to the motherboard.
  3. Ematic Funtab FTABXXX Speaker Replacement, Removing the old speaker: passo 3, imagem 1 %32
    • Carefully remove the soldered wires from the motherboard. Note the positive and negative symbol where the red and black wires are soldered to on the motherboard.
  4. Ematic Funtab FTABXXX Speaker Replacement, Soldering the new speaker: passo 4, imagem 1 %32
    • Carefully, solder the new speaker wires to the motherboard in the same fashion as the old speaker. The red wire to the '+' symbol and the black wire to the '-' symbol.
  5. Ematic Funtab FTABXXX Speaker Replacement, Positioning the speaker: passo 5, imagem 1 %32
    • Once the solder points have cooled, position the speaker into the speaker housing on the back bezel as shown in the image.
Conclusão
Robert Zarobinski
Membro desde: 01/21/15
269 Reputação
Autoria de 2 guias
Equipe
USF Tampa, Team 6-3, Brown Winter 2015 Membro de USF Tampa, Team 6-3, Brown Winter 2015
USFT-BROWN-W15S6G3
Membros da 3
Autoria de 10 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 4
Duração total: 166
