Ir para o conteúdo principal
  1. Exterior reference photos. The laptop isn't ingress-proofed, so many gaps in the keyboard and lower case, including ports, vents, speaker grilles etc may allow water damage or particle buildup. The laptop isn't ingress-proofed, so many gaps in the keyboard and lower case, including ports, vents, speaker grilles etc may allow water damage or particle buildup.
    • Exterior reference photos.
    • The laptop isn't ingress-proofed, so many gaps in the keyboard and lower case, including ports, vents, speaker grilles etc may allow water damage or particle buildup.
  2. The lower case is secured by a few Phillips screws, which are conveniently held captive, eliminating the chance of losing these screws. It also serves as encouragement from the manufacturer that yes, the user is intended to open this device, perhaps many times.
    • The lower case is secured by a few Phillips screws, which are conveniently held captive, eliminating the chance of losing these screws.
    • It also serves as encouragement from the manufacturer that yes, the user is intended to open this device, perhaps many times.
    • Nothing is left in the rear case making for painless replacement should it be broken.
    • Almost everything in the computer itself is immediately accessible, a flat design makes for easy, independent, replacement of interior components.
  3. The RAM sticks are immediately and independently accessible with no further tools. Simple clips hold them in place. The wireless cards are accessible after disconnecting the coax interconnect cables, two apiece. The cables are labeled making for painless reassembly. The standard blade-style SSD is accessible after removing a single Phillips screw, it slides right out.
    • The RAM sticks are immediately and independently accessible with no further tools. Simple clips hold them in place.
    • The wireless cards are accessible after disconnecting the coax interconnect cables, two apiece. The cables are labeled making for painless reassembly.
    • The standard blade-style SSD is accessible after removing a single Phillips screw, it slides right out.
    • The battery is replaceable after disconnecting its connector (there's even a diagram printed on the battery to explain how) and removing four labeled Phillips screws. No adhesive and immediate access make for a very simple replacement procedure.
    • The left-hand USB port is also removable at this time, secured by a single Phillips screw. Modularity of high-wear components, such as this port, is a repairability plus.
    • Additionally component locations are labeled on the motherboard and ribbon cables for additional ease of reassembly.
  4. The heatsink and speaker bar are readily removed after some screws, they can also come out upon opening, making replacement a breeze. The fan is surprisingly not removable at this point. Its captive screws aren't the only ones holding them in, there are screws attaching it from the reverse side. The fan likely won't need replacing as often as it will need cleaning so this isn't a massive detriment.
    • The heatsink and speaker bar are readily removed after some screws, they can also come out upon opening, making replacement a breeze.
    • The fan is surprisingly not removable at this point.
    • Its captive screws aren't the only ones holding them in, there are screws attaching it from the reverse side. The fan likely won't need replacing as often as it will need cleaning so this isn't a massive detriment.
    • The plastic port cover rail took a little finagling but was also removable after a couple screws. It will need to be removed in order to extract the motherboard.
  5. The trackpad has a giant piece of foam on it, which seems low quality and may collapse over time. However the foam does have a cutout that allows disconnection of the cables without removing the foam itself.
    • The trackpad has a giant piece of foam on it, which seems low quality and may collapse over time.
    • However the foam does have a cutout that allows disconnection of the cables without removing the foam itself.
    • The trackpad is a whole unit, so you don't need to remove the foam to do a replacement—unless your replacement part doesn't come with the foam, then you gotta cut it off, which is kinda annoying.
    • The fact that the frame is soldered to the trackpad probably doesn't increase the cost too much, which is good.
  6. The motherboard is also attached from the reverse of the computer, making removal slightly more complicated. The only major downside to this is that water-damage prevention usually requires speedy removal of the motherboard for cleaning—before corrosion has a chance to begin. A few remaining accessible, and modular, components include: CMOS battery and the board and plug for the optional card reader slot.
    • The motherboard is also attached from the reverse of the computer, making removal slightly more complicated.
    • The only major downside to this is that water-damage prevention usually requires speedy removal of the motherboard for cleaning—before corrosion has a chance to begin.
    • A few remaining accessible, and modular, components include: CMOS battery and the board and plug for the optional card reader slot.
  7. Back to the fan, it turns out the screws labeled KB are in fact under the keyboard. Pressing a spudger into the case cutouts  pops the latches, then the keyboard can be pried up. This seems a little more convoluted than necessary, but repair documentation makes the procedure straightforward.
    • Back to the fan, it turns out the screws labeled KB are in fact under the keyboard.
    • Pressing a spudger into the case cutouts pops the latches, then the keyboard can be pried up.
    • This seems a little more convoluted than necessary, but repair documentation makes the procedure straightforward.
  8. Surprise cables under the keyboard are long enough to open the keyboard, but don't seem long enough to lay it down safely. That said, the cables disconnect easily making the procedure painless. Keyboard assembly comes out easily. The pointer board is glued fairly stubbornly to the keyboard, but once it is freed it can be independently replaced.
    • Surprise cables under the keyboard are long enough to open the keyboard, but don't seem long enough to lay it down safely. That said, the cables disconnect easily making the procedure painless.
    • Keyboard assembly comes out easily.
    • The pointer board is glued fairly stubbornly to the keyboard, but once it is freed it can be independently replaced.
  9. With the keyboard out of the way, it could even be left attached, the fan and motherboard screws are accessible. The fan and motherboard then can be independently removed and replaced.
    • With the keyboard out of the way, it could even be left attached, the fan and motherboard screws are accessible.
    • The fan and motherboard then can be independently removed and replaced.
    • The motherboard has the majority of the computer's ports soldered to it, this is a ding to repairability, considering these components are high wear and may eventually need replacement.
  10. The display assembly is readily available for replacement upon opening the device.
    • The display assembly is readily available for replacement upon opening the device.
    • Just a few standard screws secure the hinges of the display.
    • The trackpad buttons are accessible after battery removal and the sensor after motherboard removal. Both are modular and secured with minimal, standard screws.
  11. All that remains in the case are a couple interconnect cables. These cables help add to the modularity of the device, and only cause minor inconvenience in terms of storing and replacing them, additionally they are labeled.
    • All that remains in the case are a couple interconnect cables. These cables help add to the modularity of the device, and only cause minor inconvenience in terms of storing and replacing them, additionally they are labeled.
  12. The cable cover on the display assembly is secured with plastic clips and is easy to remove. The bezel is secured with adhesive and some plastic clips. While the seam allowances seem tight, a plastic prying tool can lift the bezel without causing damage. The screen is secured with four standard screws and comes out freely.
    • The cable cover on the display assembly is secured with plastic clips and is easy to remove.
    • The bezel is secured with adhesive and some plastic clips. While the seam allowances seem tight, a plastic prying tool can lift the bezel without causing damage.
    • The screen is secured with four standard screws and comes out freely.
    • The display antennas and front-sensor array (including microphone and camera) are the remaining components in the display case.
    • Since the cables route through the display hinge they may experience stress from repeated flexing, necessitating replacement.
    • They will need to be peeled up off their adhesives an the various foil tapes will also need to be replaced without deformation, complicating repair.
  13. The HP EliteBook 800 G5 earns a 10 out of 10 on our repairability scale (10 is the easiest to repair): RAM, SSD, and battery are easily accessible and removable.
    • The HP EliteBook 800 G5 earns a 10 out of 10 on our repairability scale (10 is the easiest to repair):
    • RAM, SSD, and battery are easily accessible and removable.
    • All moving parts, including keyboard, trackpad, and pointing stick are modular and can be independently replaced.
    • The display can be quickly and independently replaced without any unnecessary disassembly.
    • All screws are standard Phillips #0 and #00, and T8 Torx.
    • Manufacturer provides free user-accessible repair documentation.
Linha de Chegada
5 outras pessoas concluíram este guia.
iRobot
Membro desde: 24/09/2009
1 Reputação
648 Guias de autoria
despite the release year specification on the repairability list, it isn’t a 2020 product and unfortunately (therefore?) cannot be purchased from the manufacturer’s website.
George - Responder
it’s also listed as a desktop computer, not a latptop
George -
These have become more difficult to repair over the years from when they previously had a hinged bottom cover, but as they have become thinner that has been replaced by screws and rubber screw caps.
But once inside, life is bliss. I repair HP, Dells and Lenovo’s all the time and HP takes top honors for documentation, disassembly (even screws are the same size!) and spare part availability, be it ebay or HP themselves. Dell is a close second, only really lacking documentation and third party component availability.
Tim Williams - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 19
Últimos 7 dias: 230
Últimos 30 dias: 517
Duração total: 6,912
