Ir para o conteúdo principal
Elenco Auto-Scan FM Radio Model FM-88K Capacitor 22 Replacement
O que você precisa
    • Remove the battery and the antenna.
    • Pre-heat the soldering iron.
    • Place hot solder iron on thermal pad, capacitor lead, and the mound of solder until solder liquefies.
    • Apply desoldering pump to remove the solder from the circuit board.
    • Repeat the instructions to remove solder from the adjacent solder mound.
    • Gently remove the capacitor by pulling the two leads out of the circuit board.
    • Place the leads of the capacitor through designated holes of the circuit board.
    • Place solder iron on the thermal pad and the lead.
    • Once this is done wait a few seconds until both items heat up.
    • Once they are heated, apply the solder to the other side so that the solder iron and the solder are not directly touching.
    • Wait 3 to 5 seconds or until enough solder covers the whole pad and forms a nice mound.
    • Remove the solder, leaving the solder iron on the pad for 2 to three seconds, then remove the solder iron.
    • Repeat for the other lead.
    • Plug the battery in and attach the antenna to test the radio.
Conclusão
4 outras pessoas executaram este guia.
Charles Riel
Membro desde: 10/10/14
218 Reputação
Autoria de 1 guia
Equipe
Charlie Riel Membro de Charlie Riel
Community
1 Membro
Autoria de 2 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 21
Duração total: 1,049
