Ir para o conteúdo principal
Electrolux Refrigerator ER9092B Capacitor Replacement
  1. Electrolux Refrigerator ER9092B Capacitor Replacement, Capacitor: passo 1, imagem 1 %32 Electrolux Refrigerator ER9092B Capacitor Replacement, Capacitor: passo 1, imagem 2 %32
    • You can verify this by measuring the supply voltage to the processors. They are Microchip 16C505s. Measure between pins 1 and 14. If the voltage is much less than 5V, say 2.5V then the most likely culprit is the large, round and in my case white capacitor. The value is 1.2uF/250V~
  2. Electrolux Refrigerator ER9092B Capacitor Replacement: passo 2, imagem 1 %32
    • The fix is to replace the capacitor. You MUST replace with a MKP-type capacitor that is rated for 250V AC. To disassemble, remove the two screws at the back of the TOP part. You also need to (temprorarily) remove the screw that holds the fridge door. Slide the top part forward and lift up.
    • The front part snaps into the rear part. Use a screwdiver to yank the small hooks to remove the front part and collect all the buttons and knobs as they fall to the floor.
    • The PCB is held in place by two small hooks. Again use a screwdriver to loosen it. Note that you will have to wiggle the lever for the fridge light to free the PCB.
  3. Electrolux Refrigerator ER9092B Capacitor Replacement: passo 5, imagem 1 %32
    • Replace the capacitor. Reassemble
Conclusão
AndersG
Membro desde: 03/10/21
121 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 12
Ao todo: 432
