Introdução
Speaker is a key component for the radio and the alarm in your electrohome EAAC475. This guide will help you to learn how to replace it, should it fail to function.
O que você precisa
Remove the 10 mm Phillips #1 screw from the battery cover.
Remove the battery cover.
Remove the two 10 mm Phillips #1 screws from the bottom of the device.
Remove two 10 mm Phillips #1 screws from the back side of the device.
Carefully and slowly detach one side from another.
Locate the speaker the inside of the back piece of the device
