Ir para o conteúdo principal
Electrohome EAAC475 Speaker Replacement
O que você precisa
  1. Electrohome EAAC475 Speaker Replacement, Battery: passo 1, imagem 1 %32 Electrohome EAAC475 Speaker Replacement, Battery: passo 1, imagem 2 %32
    • Remove the 10 mm Phillips #1 screw from the battery cover.
    • Remove the battery cover.
  2. Electrohome EAAC475 Speaker Replacement: passo 2, imagem 1 %32
    • Remove the flat lithium battery.
  3. Electrohome EAAC475 Speaker Replacement, Buttons: passo 3, imagem 1 %32 Electrohome EAAC475 Speaker Replacement, Buttons: passo 3, imagem 2 %32
    • Disconnect the radio from all power sources.
    • Remove the two 10 mm Phillips #1 screws from the bottom of the device.
    • Remove two 10 mm Phillips #1 screws from the back side of the device.
  4. Electrohome EAAC475 Speaker Replacement: passo 4, imagem 1 %32 Electrohome EAAC475 Speaker Replacement: passo 4, imagem 2 %32 Electrohome EAAC475 Speaker Replacement: passo 4, imagem 3 %32
    • Carefully and slowly pull the lower case away from the rest of the device.
    • Do not completely separate the lower case. There are several wires connecting the two halves of the device.
    • Flip the device over to access the button assembly.
    • Slowly remove the button contact board from the assembly.
  5. Electrohome EAAC475 Speaker Replacement: passo 5, imagem 1 %32 Electrohome EAAC475 Speaker Replacement: passo 5, imagem 2 %32
    • Remove the two 7 mm Phillips # 1 screws holding the buttons.
    • Remove the plastic buttons.
  6. Electrohome EAAC475 Speaker Replacement, Speaker: passo 6, imagem 1 %32 Electrohome EAAC475 Speaker Replacement, Speaker: passo 6, imagem 2 %32
    • Carefully and slowly detach one side from another.
    • Make sure the opposite sides are not separated completely.
    • Locate the speaker the inside of the back piece of the device
  7. Electrohome EAAC475 Speaker Replacement: passo 7, imagem 1 %32
    • Use the flat side of the spudger to remove the glue around the speaker.
    • This glue will need replacing when putting back the speaker.
  8. Electrohome EAAC475 Speaker Replacement: passo 8, imagem 1 %32
    • After removing all the glue around the speaker, slowly take out the speaker.
    • Be careful not to break anything surrounding the speaker while using the spudger since it is sharp.
  9. Electrohome EAAC475 Speaker Replacement: passo 9, imagem 1 %32
    • Detach the wires on the speaker and replace them with new ones.
Conclusão
Ruolin Cai
Membro desde: 02/16/16
273 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 2-1, Harley Spring 2016 Membro de IUPUI, Team 2-1, Harley Spring 2016
IUPUI-HARLEY-S16S2G1
Membros da 4
Autoria de 6 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 10
Duração total: 385
