Ir para o conteúdo principal
Electrohome EAAC475 Projector Lens Replacement
O que você precisa
  1. Electrohome EAAC475 Projector Lens Replacement, Battery: passo 1, imagem 1 %32 Electrohome EAAC475 Projector Lens Replacement, Battery: passo 1, imagem 2 %32
    • Remove the 10 mm Phillips #1 screw from the battery cover.
    • Remove the battery cover.
  2. Electrohome EAAC475 Projector Lens Replacement: passo 2, imagem 1 %32
    • Remove the flat lithium battery.
  3. Electrohome EAAC475 Projector Lens Replacement, Projector Lens: passo 3, imagem 1 %32
    • Slowly and carefully move one side away from another without detaching anything on the device.
  4. Electrohome EAAC475 Projector Lens Replacement: passo 4, imagem 1 %32
    • Detach the projector.
  5. Electrohome EAAC475 Projector Lens Replacement: passo 5, imagem 1 %32 Electrohome EAAC475 Projector Lens Replacement: passo 5, imagem 2 %32
    • Unplug the projector's connector from the circuit board.
  6. Electrohome EAAC475 Projector Lens Replacement: passo 6, imagem 1 %32
    • Take off the rubber ring.
  7. Electrohome EAAC475 Projector Lens Replacement: passo 7, imagem 1 %32 Electrohome EAAC475 Projector Lens Replacement: passo 7, imagem 2 %32 Electrohome EAAC475 Projector Lens Replacement: passo 7, imagem 3 %32
    • Using a metal spudger, pry into the crease until it separates enough to slip the spudger between the pieces.
    • Slide the tool along the crease to separate.
  8. Electrohome EAAC475 Projector Lens Replacement: passo 8, imagem 1 %32
    • Take the lens out of the projector.
  9. Electrohome EAAC475 Projector Lens Replacement: passo 9, imagem 1 %32
    • Separate the lens and the gear by unscrewing the gear.
Conclusão
Sterling Fulk
Membro desde: 02/16/16
264 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 2-1, Harley Spring 2016 Membro de IUPUI, Team 2-1, Harley Spring 2016
IUPUI-HARLEY-S16S2G1
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 7
Últimos 30 dias: 34
Ao todo: 555
