Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Locate the damaged portion of wire.
Cut the damaged plug from the lamp cord one inch below the damaged area
Separate the wire by gently pulling it apart.
The wire with the raised ribbing on the coating is the neutral wire.
The hot wire has a smooth coating.
Strip the coating off the wire.
Expose 3/4" of the copper wire.
Twist the exposed copper wire so that there is no fraying.
Loosen the screw and open the replacement plug.
The silver screw is the neutral connection, and the brass screw is the hot connection.
Wrap the neutral wire around the neutral screw. Tighten the screw to secure the wire.
Wrap the hot wire around the brass screw. Tighten the screw to secure the wire.
Thread the cord so the plug will completely close.
Tighten the exterior screw to close the plug.
18 outras pessoas executaram este guia.
7 comentários
Passt - gute Anleitung
A version for 3 prong (North American) would be great
https://www.noveltylights.com/coaxial-6-...
How would you repair a coaxial cord wire right where it enters the screw on part?
what do you do if the replacement plug has no screws to open it?
Buy a plug that can be opened with a screw
