Introdução
A common issue with electronic devices is a severed or damaged wire. Whether a dog chews through a wire, a child playing with scissors cuts a wire, or a large appliance slices through a wire, many have encountered this problem. This guide teaches how to remove a damaged plug and replace it with a new plug. The wiring in the lamp plug must be done correctly in order for the lamp to turn on after the repair is finished. This guide shows how to properly locate the "hot" and "neutral" connections.
Ferramentas
Peças
Locate the damaged portion of wire.
Cut the damaged plug from the lamp cord one inch below the damaged area
If the lamp the does not work after the replacing the plug, the issue may be located in the bulb housing or in the connections.
11 outras pessoas concluíram este guia.
2 comentários
Passt - gute Anleitung
A version for 3 prong (North American) would be great
