Ir para o conteúdo principal
Electric Wheelchair Battery Replacement
Equipamento Médico
Nem o iFixit nem este guia de reparo são endossados ou afiliados ao fabricante do dispositivo médico.
  1. Electric Wheelchair Battery Replacement, Battery to Electric Wheelchair: passo 1, imagem 1 %32 Electric Wheelchair Battery Replacement, Battery to Electric Wheelchair: passo 1, imagem 2 %32 Electric Wheelchair Battery Replacement, Battery to Electric Wheelchair: passo 1, imagem 3 %32
    • Locate the two batteries under the back of the wheelchair.
    • Pull the first battery pack to where you can reach the red battery connector.
    • Be careful, the batteries are heavy.
  2. Electric Wheelchair Battery Replacement: passo 2, imagem 1 %32 Electric Wheelchair Battery Replacement: passo 2, imagem 2 %32
    • Disconnect the red battery connectors by pulling them apart.
  3. Electric Wheelchair Battery Replacement: passo 3, imagem 1 %32 Electric Wheelchair Battery Replacement: passo 3, imagem 2 %32
    • Remove the first and second battery from the wheelchair.
  4. Electric Wheelchair Battery Replacement: passo 4, imagem 1 %32 Electric Wheelchair Battery Replacement: passo 4, imagem 2 %32
    • Disconnect the black battery connectors by pulling them apart.
  5. Electric Wheelchair Battery Replacement: passo 5, imagem 1 %32 Electric Wheelchair Battery Replacement: passo 5, imagem 2 %32 Electric Wheelchair Battery Replacement: passo 5, imagem 3 %32
    • One at a time, disconnect the clips holding each battery case closed.
    • Open each case to reveal the battery inside.
  6. Electric Wheelchair Battery Replacement: passo 6, imagem 1 %32 Electric Wheelchair Battery Replacement: passo 6, imagem 2 %32 Electric Wheelchair Battery Replacement: passo 6, imagem 3 %32
    • Remove the old battery from each case.
    • Put one new battery into each plastic case the old batteries were removed from.
  7. Electric Wheelchair Battery Replacement: passo 7, imagem 1 %32
    • Reattach the clips on each of the battery's protective casings.
  8. Electric Wheelchair Battery Replacement: passo 8, imagem 1 %32 Electric Wheelchair Battery Replacement: passo 8, imagem 2 %32 Electric Wheelchair Battery Replacement: passo 8, imagem 3 %32
    • Place the first battery back into the holder under the wheelchair.
    • Make sure that it is pushed all the way to the front of the wheelchair.
    • Place the second battery back into the holder.
  9. Electric Wheelchair Battery Replacement: passo 9, imagem 1 %32 Electric Wheelchair Battery Replacement: passo 9, imagem 2 %32 Electric Wheelchair Battery Replacement: passo 9, imagem 3 %32
    • Reconnect the black battery connectors.
    • Do not connect the red connectors until the black are connected.
    • Reconnect the red battery connectors.
    • Check that the chair turns on and is fully charged.
Linha de Chegada
3 outras pessoas executaram este guia.
Paige Efting
Membro desde: 01/19/16
159 Reputação
Autoria de 1 guia
Equipe
Um comentário
I greatly enjoyed reading your article :) Please continue publishing helpful topics like this. Regards, from <a href="http://www.scootersnchairs.com">Scooters 'N Chairs</a>.
Justin Lubomirsky - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 4
Últimos 7 dias: 23
Últimos 30 dias: 57
Duração total: 7,381
