Ir para o conteúdo principal
Electric Stove Burners and Drip Pans Replacement
O que você precisa
  1. Electric Stove Burners and Drip Pans Replacement, Burners and Drip Pans: passo 1, imagem 1 %32
    • Unplug the stove or turn off the breaker, if your stove does not allow you to unplug it.
  2. Electric Stove Burners and Drip Pans Replacement: passo 2, imagem 1 %32 Electric Stove Burners and Drip Pans Replacement: passo 2, imagem 2 %32 Electric Stove Burners and Drip Pans Replacement: passo 2, imagem 3 %32
    • Slide the burners out of the receptacle block.
    • The prongs attached to the burner in the second image fit the slots in the receptacle block in the third image.
  3. Electric Stove Burners and Drip Pans Replacement: passo 3, imagem 1 %32
    • Lift the drip pan out of the stove.
  4. Electric Stove Burners and Drip Pans Replacement: passo 4, imagem 1 %32 Electric Stove Burners and Drip Pans Replacement: passo 4, imagem 2 %32
    • Wipe the surface underneath the drip pan to clean it and ensure there are no food remnants
  5. Electric Stove Burners and Drip Pans Replacement: passo 5, imagem 1 %32 Electric Stove Burners and Drip Pans Replacement: passo 5, imagem 2 %32
    • If all the wires look satisfactory, add the new drip pan.
    • Ensure you have the burner with the open ring so the prongs reach the receptacle block.
  6. Electric Stove Burners and Drip Pans Replacement: passo 6, imagem 1 %32
    • Slide new burner through the receptacle.
    • Reassemble stove after.
Linha de Chegada
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 29
Últimos 30 dias: 114
Duração total: 3,983
