Ir para o conteúdo principal
Electric Lint Remover Blade Replacement
O que você precisa
  1. Electric Lint Remover Blade Replacement, Blade: passo 1, imagem 1 %32 Electric Lint Remover Blade Replacement, Blade: passo 1, imagem 2 %32
    • Remove the lint container by sliding to the right until it clicks off.
    • Remove any lint from the lint container for a clean process.
  2. Electric Lint Remover Blade Replacement: passo 2, imagem 1 %32 Electric Lint Remover Blade Replacement: passo 2, imagem 2 %32 Electric Lint Remover Blade Replacement: passo 2, imagem 3 %32
    • Rotate the perforated cap counterclockwise until it can be removed.
  3. Electric Lint Remover Blade Replacement: passo 3, imagem 1 %32 Electric Lint Remover Blade Replacement: passo 3, imagem 2 %32
    • Use your flathead screwdriver to get in between the device and the blades.
    • Push the plastic blade holder outward from the device until it pops off.
  4. Electric Lint Remover Blade Replacement: passo 4, imagem 1 %32 Electric Lint Remover Blade Replacement: passo 4, imagem 2 %32
    • Lift the wire out of the defective blade's hole, using the flathead screwdriver.
  5. Electric Lint Remover Blade Replacement: passo 5, imagem 1 %32 Electric Lint Remover Blade Replacement: passo 5, imagem 2 %32 Electric Lint Remover Blade Replacement: passo 5, imagem 3 %32
    • Insert the replacement blade into the empty slot.
    • Caution: pinching the replacement blade from surface may result in injury.
  6. Electric Lint Remover Blade Replacement: passo 6, imagem 1 %32 Electric Lint Remover Blade Replacement: passo 6, imagem 2 %32
    • Flip the cap onto its backside and firmly hold down the side with the loose blade.
    • Pull back the wire using your fingers, and insert wire back into the blade hole.
  7. Electric Lint Remover Blade Replacement: passo 7, imagem 1 %32 Electric Lint Remover Blade Replacement: passo 7, imagem 2 %32 Electric Lint Remover Blade Replacement: passo 7, imagem 3 %32
    • Insert the plastic blade holder back on the shaft of the device, by aligning the hexagonal hole on the cap with the shaft.
    • Press down gently on the plastic blade cap.
    • Caution: Make sure to press on the cap and not on the blades, otherwise action may cause injury.
  8. Electric Lint Remover Blade Replacement: passo 8, imagem 1 %32 Electric Lint Remover Blade Replacement: passo 8, imagem 2 %32
    • Place perforated cap on top of the blade cap and turn clockwise until tight.
  9. Electric Lint Remover Blade Replacement: passo 9, imagem 1 %32 Electric Lint Remover Blade Replacement: passo 9, imagem 2 %32
    • Slide the lint container to the left and press until it clicks into place.
Conclusão
We hope this guide helped you. Happy Fixing!
Chris Koenig
Membro desde: 10/03/23
169 Reputação
Autoria de 1 guia
Equipe
CSU Los Angeles, Team 9-4, Ribeiro Fall 2023 Membro de CSU Los Angeles, Team 9-4, Ribeiro Fall 2023
CSULA-RIBEIRO-F23S9G4
Membros da 3
1 Guia de autoria
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 31
Duração total: 240
