Introdução
Use this guide to replace the top feeder assembly in the auto-feeder in your Electric Eel 75’ Drain Cleaner Z5K12IC75AF.
O que você precisa
Twist the guide spring counter-clockwise to unscrew it from the auto-feeder.
Remove the guide spring.
Unscrew the tension knob to loosen the tension spring in the top feeder assembly.
Set the feeder adjustment knob in the neutral position, in between the "FWD" and "REV" positions.
Use a 1/2" open-ended wrench to remove the two bolts from the bottom of the feeder body mounting arm.
Use a vise to compress the roll pin until there is no longer space in the roll pin's slot.
Unscrew and remove the tension knob from the top feeder assembly.
Use a 9/64" hex key to remove the three bolts from the top of the feeder.
Use a flat head screwdriver to remove the top control finger.
Insert a flathead screwdriver or other long tool underneath the tension spring in the top feeder assembly.
Use the tool to push up on the spring and ball bearing carrier so you can remove them by hand.
Use a flathead screwdriver or other long tool to push up on the bearing carrier so you can remove it by hand.
After reassembly: Ensure the assembly you just installed is sufficiently lubricated using the Zerk fitting on the feeder body.
Uma outra pessoa concluiu este guia.
