Ir para o conteúdo principal
Electric Bike Throttle Replacement
O que você precisa
  1. Electric Bike Throttle Replacement, Brake: passo 1, imagem 1 %32
    • Before starting to disassemble your electric bike, turn the power off.
    • Remove the 3/32 inch Allen screw.
    • When removing Allen screw, make sure the driver is well seated because they are simple to strip.
  2. Electric Bike Throttle Replacement, Throttle: passo 2, imagem 1 %32
    • Locate the throttle Allen screw.
    • Remove the 5/64 inch Allen screw.
  3. Electric Bike Throttle Replacement, Throttle: passo 3, imagem 1 %32
    • Slide the Throttle off.
    • When removing the throttle, be careful. Remove it slowly to avoid damaging the wire.
  4. Electric Bike Throttle Replacement, Control Box: passo 4, imagem 1 %32
    • Remove the following screws.
    • 2 mm Philips screws.
  5. Electric Bike Throttle Replacement: passo 5, imagem 1 %32
    • Open up the control box.
  6. Electric Bike Throttle Replacement: passo 6, imagem 1 %32
    • Track the throttle wire.
    • To ensure you don't lose it, you should mark it.
  7. Electric Bike Throttle Replacement: passo 7, imagem 1 %32
    • Locate the throttle wire.
    • Disconnect the throttle wire plug from the controller wire plug.
    • Take caution while handling these wires. You can easily damage them.
Conclusão
Ali Al-hamadani
Membro desde: 10/06/22
145 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 30
Ao todo: 1,406
