Ir para o conteúdo principal
Egg Slicer Wire Replacement
O que você precisa
  1. Egg Slicer Wire Replacement, Wire: passo 1, imagem 1 %32 Egg Slicer Wire Replacement, Wire: passo 1, imagem 2 %32
    • Do not repeatedly bend clamps. This weakens the metal and makes it more susceptible to damage.
    • It is strongly recommended that you wear personal protective equipment when completing this repair. The wires may present a pinching or scratching hazard.
    • Using the flat nosed pliers, pry the clamp open.
    • Grip the clamp and bend to a 90 degree angle.
    • Repeat this step for every clamp.
  2. Egg Slicer Wire Replacement: passo 2, imagem 1 %32
    • Unwind the old wire from the slicer.
    • Extend the wire and put to the side.
    • You should now be left with the skeleton of the egg slicer.
  3. Egg Slicer Wire Replacement: passo 3, imagem 1 %32 Egg Slicer Wire Replacement: passo 3, imagem 2 %32
    • Take the old wire and extend it out as much as possible.
    • Straighten out any bends in the old wire for accuracy.
    • Place your old wire at the 0 mark of the measuring tape.
    • Take the measurement of your old wire and take note of its length.
    • It is recommended that you mark the length of your old wire on your measuring tape.
    • Use the length you recorded to cut a new wire and put it to the side.
  4. Egg Slicer Wire Replacement: passo 4, imagem 1 %32 Egg Slicer Wire Replacement: passo 4, imagem 2 %32
    • Take the new wire, and anchor it by tying it in a loop around one of the clamp.
    • Pull the wire as tight as possible to the right side of clamp.
  5. Egg Slicer Wire Replacement: passo 5, imagem 1 %32 Egg Slicer Wire Replacement: passo 5, imagem 2 %32 Egg Slicer Wire Replacement: passo 5, imagem 3 %32
    • Loop the wire tightly around the clamp.
    • Rotate the wire in a counterclockwise direction.
    • When you reach the clamp across from it, loop it around the clamp, and pull the wire to clamp to the right of it.
    • Repeat these steps until you reach the final clamp.
  6. Egg Slicer Wire Replacement: passo 6, imagem 1 %32 Egg Slicer Wire Replacement: passo 6, imagem 2 %32 Egg Slicer Wire Replacement: passo 6, imagem 3 %32
    • Before anchoring the loop, make sure that you have pulled the wires to be as tight as possible.
    • Once at the final clamp repeat step 4.
    • Anchor the loop by looping the wire as tight as possible.
  7. Egg Slicer Wire Replacement: passo 7, imagem 1 %32
    • With the flat nosed pliers, clamp down all the clamps.
    • Cut any excess wire so you have a sturdy fit for your new wire.
Linha de Chegada
Uma outra pessoa concluiu este guia.
Diego Jimenez 213
Membro desde: 02/19/25
145 Reputação
Autoria de 1 guia
Equipe
UC Davis, Team 2-6, Andersen Winter 2025 Membro de UC Davis, Team 2-6, Andersen Winter 2025
UCD-ANDERSEN-W25S2G6
3 Membros
1 Guia de autoria
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 36
Ao todo: 114
