Ir para o conteúdo principal
Edwin the Duck Rubber Gasket Seal Replacement
O que você precisa
  1. Edwin the Duck Rubber Gasket Seal Replacement, Rubber Gasket Seal: passo 1, imagem 1 %32 Edwin the Duck Rubber Gasket Seal Replacement, Rubber Gasket Seal: passo 1, imagem 2 %32
    • Unscrew the four 9mm screws with aT8 bit
    • Take the back plate off
  2. Edwin the Duck Rubber Gasket Seal Replacement: passo 2, imagem 1 %32 Edwin the Duck Rubber Gasket Seal Replacement: passo 2, imagem 2 %32
    • Carefully take off the rubber skin.
    • Be patient and don't rush. You don't want to rip or damage the rubber skin otherwise you will lose the waterproof cover.
  3. Edwin the Duck Rubber Gasket Seal Replacement: passo 3, imagem 1 %32
    • Using the J1 bit, unscrew all six 9 mm screws around the border.
  4. Edwin the Duck Rubber Gasket Seal Replacement: passo 4, imagem 1 %32 Edwin the Duck Rubber Gasket Seal Replacement: passo 4, imagem 2 %32
    • Use the plastic opening tool to open the inside of the duck.
    • Be very careful when splitting the two halves apart. There are wires connecting to both sides. So open it very slowly.
  5. Edwin the Duck Rubber Gasket Seal Replacement: passo 5, imagem 1 %32 Edwin the Duck Rubber Gasket Seal Replacement: passo 5, imagem 2 %32
    • Remove the rubber gasket
  6. Edwin the Duck Rubber Gasket Seal Replacement: passo 6, imagem 1 %32
    • Insert your new rubber gasket in and use the plastic opening tool to push the rubber gasket into it's slot
Conclusão
Equipe
UW Tacoma, Team S1-G4, Rose Fall 2017 Membro de UW Tacoma, Team S1-G4, Rose Fall 2017
UWT-ROSE-F17S1G4
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 302
