Ir para o conteúdo principal
Edwin the Duck Motherboard Replacement
O que você precisa
  1. Edwin the Duck Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 Edwin the Duck Motherboard Replacement, Motherboard: passo 1, imagem 2 %32
    • Unscrew the four 9mm screws with a T8 screwdriver bit
    • Remove the back plate off
  2. Edwin the Duck Motherboard Replacement: passo 2, imagem 1 %32 Edwin the Duck Motherboard Replacement: passo 2, imagem 2 %32
    • Carefully take off the rubber skin.
    • Be patient and don't rush. You don't want to rip or damage the rubber skin resulting in losing the waterproof cover.
  3. Edwin the Duck Motherboard Replacement: passo 3, imagem 1 %32
    • Using the J1 screwdriver bit, unscrew all six 9 mm screws that run along the border.
  4. Edwin the Duck Motherboard Replacement: passo 4, imagem 1 %32 Edwin the Duck Motherboard Replacement: passo 4, imagem 2 %32
    • Use the plastic opening tool to open the inside of the duck.
    • Be very careful when splitting the two halves apart. There are wires connecting to both sides. Remember to open slowly.
  5. Edwin the Duck Motherboard Replacement: passo 5, imagem 1 %32 Edwin the Duck Motherboard Replacement: passo 5, imagem 2 %32
    • Using the plastic opening tool pull up the black tab up until it stops.
    • Be careful not to pull up the black tab too far up, otherwise the cable won't be secure anymore.
    • Pull up the white cable tab, up slowly
  6. Edwin the Duck Motherboard Replacement: passo 6, imagem 1 %32
    • Use the J1 screwdriver bit to unscrew all four 9 mm screws attached to the motherboard.
  7. Edwin the Duck Motherboard Replacement: passo 7, imagem 1 %32
    • Remove the top connector as you see in the picture.
    • Replace the new motherboard and you are finished.
Conclusão
Uma outra pessoa concluiu este guia.
Caleb Kim
Membro desde: 10/18/17
143 Reputação
Autoria de 1 guia
Equipe
UW Tacoma, Team S1-G4, Rose Fall 2017 Membro de UW Tacoma, Team S1-G4, Rose Fall 2017
UWT-ROSE-F17S1G4
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 8
Duração total: 419
