Introdução
The motherboard is a crucial aspect to controlling the Ecovacs Deebot 900. Unfortunately, the motherboard is easily fried if the robot accidentally vacuums water and may need to be replaced. Use this guide to replace the motherboard in the Ecovacs Deebot 900.
O que você precisa
Using a Phillips #00 screwdriver, remove the eight screws on the bottom edge of the bumper.
Using a Phillips #00 screwdriver, take out the six screws around the perimeter of the bottom case.
Using a Phillips #00 screwdriver, remove the two black screws holding the motherboard in place.
4 outras pessoas executaram este guia.
2 comentários
Any suggestions on purchase options?
vakum ozmo 900,hidup terus mati,lampu led juga mati,switch masih posisi on
