Ir para o conteúdo principal
Ecovacs Deebot 900 Front Bumper Replacement
O que você precisa
  1. Ecovacs Deebot 900 Front Bumper Replacement, Battery: passo 1, imagem 1 %32
    • Remove all the brushes from the Deebot.
  2. Ecovacs Deebot 900 Front Bumper Replacement: passo 2, imagem 1 %32
    • Using a Phillips #0 screwdriver, remove the two 12.25 mm screws holding the battery cover in place.​
  3. Ecovacs Deebot 900 Front Bumper Replacement: passo 3, imagem 1 %32
    • Remove the battery cover.
  4. Ecovacs Deebot 900 Front Bumper Replacement: passo 4, imagem 1 %32
    • Using the two white straps on the sides of the battery, gently remove the battery. ​
    • Be careful not to rip out the battery cable.
  5. Ecovacs Deebot 900 Front Bumper Replacement: passo 5, imagem 1 %32
    • Carefully disconnect the battery cable by pulling near the connector at the bottom of the battery compartment.
  6. Ecovacs Deebot 900 Front Bumper Replacement, Front Bumper: passo 6, imagem 1 %32 Ecovacs Deebot 900 Front Bumper Replacement, Front Bumper: passo 6, imagem 2 %32
    • Using a Phillips #00 screwdriver, remove the eight screws on the bottom edge of the bumper. ​
  7. Ecovacs Deebot 900 Front Bumper Replacement: passo 7, imagem 1 %32
    • Remove the black strip on the bottom of the bumper.
  8. Ecovacs Deebot 900 Front Bumper Replacement: passo 8, imagem 1 %32 Ecovacs Deebot 900 Front Bumper Replacement: passo 8, imagem 2 %32
    • Carefully lift up the bumper untill it pops out of place.​
  9. Ecovacs Deebot 900 Front Bumper Replacement: passo 9, imagem 1 %32 Ecovacs Deebot 900 Front Bumper Replacement: passo 9, imagem 2 %32
    • Disconnect the two cables connecting the bumper to the body of the Deebot.
    • Remove the front bumper from the device.
Conclusão
Uma outra pessoa concluiu este guia.
Um comentário
Where may I buy the front bumper assembly? I'm trying to replace one for a deebot 901 but the mfg tells me they don't see the part directly.
Chris Khacherian - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 12
Últimos 7 dias: 59
Últimos 30 dias: 245
Duração total: 9,904
