Ir para o conteúdo principal
Ecovacs DEEBOT D35 Vacuum Motor Replacement
O que você precisa
  1. Ecovacs DEEBOT D35 Vacuum Motor Replacement, Vacuum Motor: passo 1, imagem 1 %32
    • Lay the Deebot face down so you have access to the battery compartment. Remove the battery.
  2. Ecovacs DEEBOT D35 Vacuum Motor Replacement: passo 2, imagem 1 %32
    • Locate the 9 screws that secure the back cover. Remove with a PH2 Phillips Head Screwdriver. The screws are:
    • 7 x 14mm screws
    • 2 x 10mm screws
  3. Ecovacs DEEBOT D35 Vacuum Motor Replacement: passo 3, imagem 1 %32
    • Use a spudger or plastic opening tool to separate the Deebot backside.
  4. Ecovacs DEEBOT D35 Vacuum Motor Replacement: passo 4, imagem 1 %32
    • Carefully lift the back cover from the body of the Deebot to expose the internal wiring harnesses.
  5. Ecovacs DEEBOT D35 Vacuum Motor Replacement: passo 5, imagem 1 %32
    • There are 5 wiring harnesses that need to be disconnected before completely removing the back cover.
    • There are two blue wiring harnesses on the front left and right side (located next to the sensor). They are represented by the red circles.
    • There is a multicolor wiring harness on the front center. This is represented by the orange circle.
    • Two black and red wiring harnesses are connected to the motherboard. This is represented by the yellow circles.
  6. Ecovacs DEEBOT D35 Vacuum Motor Replacement: passo 6, imagem 1 %32
    • Locate the 4 screws on the vacuum motor.
  7. Ecovacs DEEBOT D35 Vacuum Motor Replacement: passo 7, imagem 1 %32
    • Remove the screws from the vacuum motor body with a PH2 Phillips Head Screwdriver. The screws are:
    • 4 x 10mm screws
  8. Ecovacs DEEBOT D35 Vacuum Motor Replacement: passo 8, imagem 1 %32
    • Remove the vacuum motor body
Conclusão
3 outras pessoas executaram este guia.
Brian
Membro desde: 02/15/17
475 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 12-2, Eyestone Spring 2017 Membro de USF Tampa, Team 12-2, Eyestone Spring 2017
USFT-EYESTONE-S17S12G2
Membros da 4
Autoria de 4 guias
Um comentário
thanks a lots for the valuable info
sk law - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 17
Duração total: 8,972
