Ir para o conteúdo principal
Ecovacs DEEBOT D35 Motherboard Replacement
O que você precisa
  1. Ecovacs DEEBOT D35 Motherboard Replacement, Motherboard: passo 1, imagem 1 %32
    • Flip the D35 onto its back.
  2. Ecovacs DEEBOT D35 Motherboard Replacement: passo 2, imagem 1 %32
    • Remove the 9 screws with a PH2 Phillips screwdriver on the underside of the D35. The screws are:
    • 7 x 14mm screws
    • 2 x 10mm screws
  3. Ecovacs DEEBOT D35 Motherboard Replacement: passo 3, imagem 1 %32
    • Use spudger or plastic opening tool to separate the Deebot backside
  4. Ecovacs DEEBOT D35 Motherboard Replacement: passo 4, imagem 1 %32
    • Carefully lift the back cover from the body of the Deebot
  5. Ecovacs DEEBOT D35 Motherboard Replacement: passo 5, imagem 1 %32 Ecovacs DEEBOT D35 Motherboard Replacement: passo 5, imagem 2 %32
    • There are 5 cables that need to be carefully disconnected before completely disconnecting the back cover:
    • The 5 cables two blue cables on the front left and right side (located next to the sensor). Represented by the red arrows.
    • Multicolor ribbon in the front center. Represented by the blue arrow.
    • Two (black and red) two prong adapter connected to the motherboard. Represented by the green arrow.
  6. Ecovacs DEEBOT D35 Motherboard Replacement: passo 6, imagem 1 %32 Ecovacs DEEBOT D35 Motherboard Replacement: passo 6, imagem 2 %32 Ecovacs DEEBOT D35 Motherboard Replacement: passo 6, imagem 3 %32
    • Locate the 3 screws on the motherboard:
    • 2 x 14mm screws
    • 1 x 10mm screws
  7. Ecovacs DEEBOT D35 Motherboard Replacement: passo 7, imagem 1 %32
    • Remove the screws from the motherboard with a PH2 Phillips Head Screwdriver. The screws are:
    • 2 x 14mm screws
    • 1 x 10mm screws
  8. Ecovacs DEEBOT D35 Motherboard Replacement: passo 8, imagem 1 %32 Ecovacs DEEBOT D35 Motherboard Replacement: passo 8, imagem 2 %32
    • Locate and disconnect 12 cables bundles connected on the motherboard
  9. Ecovacs DEEBOT D35 Motherboard Replacement: passo 9, imagem 1 %32
    • Carefully disconnect the motherboard from the Deebot body.
Conclusão
Kevin McKernan
Membro desde: 02/15/17
107 Reputação
Autoria de 1 guia
Equipe
USF Tampa, Team 12-2, Eyestone Spring 2017 Membro de USF Tampa, Team 12-2, Eyestone Spring 2017
USFT-EYESTONE-S17S12G2
Membros da 4
Autoria de 4 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 13
Duração total: 2,715
