Ir para o conteúdo principal
Ecovacs DEEBOT D35 Battery Replacement
O que você precisa
  1. Ecovacs DEEBOT D35 Battery Replacement, Battery: passo 1, imagem 1 %32
    • Press and hold the tabs on both sides of the battery.
  2. Ecovacs DEEBOT D35 Battery Replacement: passo 2, imagem 1 %32
    • Remove the battery from the Deebot
  3. Ecovacs DEEBOT D35 Battery Replacement: passo 3, imagem 1 %32
    • Remove the screw attaching the battery housing.
  4. Ecovacs DEEBOT D35 Battery Replacement: passo 4, imagem 1 %32
    • Inert the new battery casing into the housing.
    • Replace the screw attaching the housing.
    • Replace the batter housing in the Deebot.
Conclusão
3 outras pessoas executaram este guia.
Brian
Membro desde: 02/15/17
475 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 12-2, Eyestone Spring 2017 Membro de USF Tampa, Team 12-2, Eyestone Spring 2017
USFT-EYESTONE-S17S12G2
Membros da 4
Autoria de 4 guias
7 comentários
How do you actually take the battery pack out of the casing?
Jonathan A - Responder
Where can i find a replacement battery for deebot model d35
Travis neas - Responder
JonathanA - you don't, it comes complete in the casing and can not be opened.
Kate Oe - Responder
But where can we buy a replacement battery for deebot 35?
Kay Pott - Responder
Where can i buy a replacement battery for D35
Terry Martin
Terry Martin -
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 11
Últimos 30 dias: 57
Duração total: 13,966
