Ir para o conteúdo principal
Eco X Gear Voice Coil Replacement
O que você precisa
  1. Eco X Gear Voice Coil Replacement, Frame: passo 1, imagem 1 %32
    • Disconnect any power source and/or turn off device.
  2. Eco X Gear Voice Coil Replacement: passo 2, imagem 1 %32
    • Remove the 15 rubber plugs from the cavities using needle nose pliers.
  3. Eco X Gear Voice Coil Replacement: passo 3, imagem 1 %32
    • Use a phillips head screwdriver to remove the fifteen 6.4mm screws.
  4. Eco X Gear Voice Coil Replacement: passo 4, imagem 1 %32
    • Carefully separate the two sections of the frame.
    • Wires still connect the two sections. Be cautious to avoid damaging the wires, terminals, and electronics.
  5. Eco X Gear Voice Coil Replacement, Voice Coil: passo 5, imagem 1 %32
    • Disconnect the wiring to improve accessibility to the cones.
  6. Eco X Gear Voice Coil Replacement: passo 6, imagem 1 %32 Eco X Gear Voice Coil Replacement: passo 6, imagem 2 %32
    • Remove the four screws that hold down the speaker and pry up the speaker from the frame.
  7. Eco X Gear Voice Coil Replacement: passo 7, imagem 1 %32
    • Once the voice coil is removed, solder it back onto the bracket or replace the voice coil entirely.
Conclusão
James Lipsett
Membro desde: 03/20/17
625 Reputação
Autoria de 6 guias
Equipe
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 4
Duração total: 175
