Introdução
You will need a phillips head screw driver, needle nose pliers, solder, and a soldering iron to complete this task. Before opening the device, ensure that there is no power to avoid damaging the electronics or harming yourself.
O que você precisa
Locate the terminals coming off of the backside of the LED lights. Cut the terminals to remove the light from the frame.
Quase terminado!
Conclusão
