Introdução
You will need a phillips head screw driver and needle nose pliers to complete this task. Before opening the device, ensure that there is no power to avoid damaging the electronics or harming yourself.
O que você precisa
Inspect the gasket around the perimeter of the frame. Remove the gasket using your fingers or needle nose pliers.
Quase terminado!
Conclusão
