Ir para o conteúdo principal
Eco X Gear Battery Replacement
O que você precisa
  1. Eco X Gear Battery Replacement, Frame: passo 1, imagem 1 %32
    • Disconnect any power source and/or turn off device.
  2. Eco X Gear Battery Replacement: passo 2, imagem 1 %32
    • Remove the 15 rubber plugs from the cavities using needle nose pliers.
  3. Eco X Gear Battery Replacement: passo 3, imagem 1 %32
    • Use a phillips head screwdriver to remove the fifteen 6.4mm screws.
  4. Eco X Gear Battery Replacement: passo 4, imagem 1 %32
    • Carefully separate the two sections of the frame.
    • Wires still connect the two sections. Be cautious to avoid damaging the wires, terminals, and electronics.
  5. Eco X Gear Battery Replacement, Battery: passo 5, imagem 1 %32
    • Disconnect the wiring to improve accessibility to the battery.
  6. Eco X Gear Battery Replacement: passo 6, imagem 1 %32 Eco X Gear Battery Replacement: passo 6, imagem 2 %32
    • Remove the two screws that hold that bracket, securing the battery in place.
  7. Eco X Gear Battery Replacement: passo 7, imagem 1 %32
    • Disconnect the wires that hold the batteries down to the motherboard.
  8. Eco X Gear Battery Replacement: passo 8, imagem 1 %32
    • Pry the battery from the frame using your hands or an opening pick.
  9. Eco X Gear Battery Replacement: passo 9, imagem 1 %32
    • When removing and installing the battery, be cautious to not damage any of the surrounding electronics.
Conclusão
Uma outra pessoa concluiu este guia.
James Lipsett
Membro desde: 03/20/17
625 Reputação
Autoria de 6 guias
Equipe
3 comentários
Where to get the new battery?
James Chen - Responder
Hello EcoXGear lovers, i just bought this battery from amazon yesterday and perfect fit with polarity you can get the battery here
https://www.amazon.com/gp/product/B08ZCQ...
partha - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 5
Últimos 30 dias: 28
Duração total: 667
