Introdução
This guide is used when the toggle button is no longer functioning properly. If you are experiencing a loose or broken toggle button it must be replaced to keep the device operating normally.
O que você precisa
Using the screwdriver with the J00 bit, remove the two 4.8 mm Phillips screws.
Use the angled tweezers to disconnect the toggle button covering.
Quase terminado!
Conclusão
