Ir para o conteúdo principal
Eclipse MTE28VGM Battery Replacement
O que você precisa
  1. Eclipse MTE28VGM Battery Replacement, Battery Replacement: passo 1, imagem 1 %32 Eclipse MTE28VGM Battery Replacement, Battery Replacement: passo 1, imagem 2 %32 Eclipse MTE28VGM Battery Replacement, Battery Replacement: passo 1, imagem 3 %32
    • Using the screwdriver with the J00 bit, remove the two 4.8 mm Phillips screws.
    • Use caution when removing the screws as they can strip easily.
  2. Eclipse MTE28VGM Battery Replacement: passo 2, imagem 1 %32 Eclipse MTE28VGM Battery Replacement: passo 2, imagem 2 %32 Eclipse MTE28VGM Battery Replacement: passo 2, imagem 3 %32
    • Using the small metal pry bar, remove the bottom plastic cover.
    • Using your thumb, press down on the home button and hold the metal casing. With your other hand hold the top plastic part of the device. At the same time slide the metal casing and the plastic casing apart.
    • On occasion the battery can become swollen and make this process difficult. You might need to use the spudger to push on the bottom components to assist in the separation.
  3. Eclipse MTE28VGM Battery Replacement: passo 3, imagem 1 %32 Eclipse MTE28VGM Battery Replacement: passo 3, imagem 2 %32 Eclipse MTE28VGM Battery Replacement: passo 3, imagem 3 %32
    Ferramenta utilizada neste passo:
    • Using the straight tweezers, remove the plastic coating on the wires.
  4. Eclipse MTE28VGM Battery Replacement: passo 4, imagem 1 %32 Eclipse MTE28VGM Battery Replacement: passo 4, imagem 2 %32 Eclipse MTE28VGM Battery Replacement: passo 4, imagem 3 %32
    • Using the soldering guide, desolder the battery connections.
    • Soldering is a dangerous process, and caution needs to be taken to avoid injury.
Conclusão
Uma outra pessoa concluiu este guia.
Brendon Yates
Membro desde: 09/29/16
309 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 2-1, Harley Fall 2016 Membro de IUPUI, Team 2-1, Harley Fall 2016
IUPUI-HARLEY-F16S2G1
Membros da 4
Autoria de 12 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Duração total: 406
