Ir para o conteúdo principal
Eclipse 180G2 Outer Case Replacement
O que você precisa
  1. Eclipse 180G2 Outer Case Replacement, Outer Case: passo 1, imagem 1 %32 Eclipse 180G2 Outer Case Replacement, Outer Case: passo 1, imagem 2 %32
    • Remove the two screws on the bottom of the device with a Phillips head screwdriver.
    • Use a spudger to remove the plastic plate from the bottom of the player.
  2. Eclipse 180G2 Outer Case Replacement, Remove inner circuit from case shell: passo 2, imagem 1 %32 Eclipse 180G2 Outer Case Replacement, Remove inner circuit from case shell: passo 2, imagem 2 %32 Eclipse 180G2 Outer Case Replacement, Remove inner circuit from case shell: passo 2, imagem 3 %32
    • Hold the device firmly between two fingers. Be sure you aren't holding down the top of the device; the circuit board will slide out of the shell through that end.
    • Use the spudger to push the USB port on the bottom of the device inward.
    • The plastic LCD cover and the key pad will now be free; they were held in place by the tension between the case and the internal circuit board.
Conclusão
3 outras pessoas executaram este guia.
Jesse Minor
Membro desde: 01/15/15
662 Reputação
Autoria de 3 guias
Equipe
USF Tampa, Team 1-4, Tanski Winter 2015 Membro de USF Tampa, Team 1-4, Tanski Winter 2015
USFT-TANSKI-W15S1G4
Membros da 4
Autoria de 5 guias
Um comentário
What if there is no charge port or USB port there no longer?
May 303 - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 14
Duração total: 1,361
